At a glance
2.42in 61mm
CPM® S30V®
United States
SlipIt
About
One of the newest members of Spyderco’s unique breed of non-locking folders, the Lil’ Native® SLIPIT™ replaces the Compression Lock® and back lock of the original models with Spyderco’s “notched joint” mechanism. An enhanced version of a traditional slipjoint, this mechanism uses spring pressure to hold the knife’s full-flat-ground CPM® S30V® blade open but does not lock it. Peel ply-textured G-10 scales and an index-finger choil ensure a secure, non-slip grip and a broad based four-position clip offers ambidextrous tip-up or tip-down carry.
Technical specifications
Lock
SlipIt
Blade Length:
2.42in 61mm
Overall length:
5.9in 150mm
Closed length:
3.47in 88mm
Edge Length:
2.02in 51mm
CPM® S30V®
Blade thickness:
.13in 3.2mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
G-10
Knife weight:
2.5oz 71g
Grind:
