At a glance
2.45in 62mm
CPM® SPY27®
United States
Compression
About
The MicroJimbo® distills all the key features of Michael Janich’s trendsetting Yojimbo® 2 design into a smaller, more legally compliant package, while keeping its critical dimensional relationships the same. The result is an ultra-compact “tactical Wharncliffe” folding knife that deploys exactly like its full-sized counterpart, while fitting smaller hands and pockets perfectly. This elite version of the MicroJimbo enhances the design even further with a blade crafted from our proprietary CPM® SPY27® stainless steel. An improved, powder-metallurgy expression of time-honored VG-10 stainless steel, CPM SPY27’s advanced alloy formula contains vanadium, molybdenum, niobium, and nitrogen, all enhanced by the amplifying effects of the steel’s signature element—cobalt. Together they create a blade steel that offers an impressive balance of edge retention, toughness, and corrosion resistance. The MicroJimbo’s full-flat-ground Wharncliffe blade takes full advantage of these properties to deliver cutting performance far beyond its compact size. It is paired with a handle featuring nested, skeletonized stainless steel liners, cobalt blue peel-ply-textured G-10 scales, and a high-strength Compression Lock® mechanism. To balance discreet carry and immediate access, the MicroJimbo includes a deep-pocket wire clip that is reversible for left or right-side tip-up carry.
Technical specifications
Lock
Compression
Blade Length:
2.45in 62mm
Overall length:
6.22in 158mm
Closed length:
3.8in 97mm
Edge Length:
2.23in 57mm
CPM® SPY27®
Blade thickness:
.15in 3.7mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
G-10
Knife weight:
2.9oz 81g
Grind:
