At a glance
4in 102mm
CPM® SPY27®
United States
Compression
About
The second-generation Military 2 enhances the venerable Military model with the addition of a high-strength Compression Lock® mechanism and the versatility of a four-position pocket clip. This expression raises the bar even higher with a blade crafted from Spyderco’s proprietary CPM SPY27 steel. Starting with the time-tested alloy formula of VG-10 stainless steel, SPY27 increases the volumes of carbon, molybdenum, and vanadium and adds niobium and nitrogen. Crucible® Industries’ state-of-the-art particle metallurgy manufacturing process then ensures a uniform distribution of these alloys throughout the steel. The result is an extremely homogeneous microstructure that maximizes the steel’s edge holding, toughness, and corrosion resistance. To further distinguish this knife as a member of Spyderco’s elite SPY27 family, its handle features peel-ply-textured G-10 scales in a signature cobalt-blue color.
Technical specifications
Lock
Compression
Blade Length:
4in 102mm
Overall length:
9.51in 242mm
Closed length:
5.51in 140mm
Edge Length:
3.65in 93mm
CPM® SPY27®
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
G-10
Knife weight:
4.4oz 124g
Grind:
