Military 2 Salt® CPM® MagnaCut® Black C36GMCBKP2_Both
Black
$319.00
Skip to product information
SKU:C36GMCBKP2
SKU:C36GMCBKP2
$319.00
Color
At a glance
4in 102mm
CPM® MagnaCut®
United States
Compression
About
The second-generation Military 2 elevates the time-tested Military™ Model with the addition of a high-strength Compression Lock® mechanism and a four-position pocket clip that supports all possible carry preferences. Our remarkable Salt® Series expressions of the Military 2 raise the bar yet again by expressing the design with state-of-the-art, ultra-corrosion-resistant materials. Their full-flat-ground blades are crafted from CPM® MagnaCut®—a revolutionary particle metallurgy steel that defies conventional stainless steel metallurgy to deliver an incredible balance of edge retention, toughness, and extreme corrosion resistance. These elite blades are paired with easy-to-clean, open-backed handles featuring G-10 scales and nested, skeletonized stainless steel liners. The skeletonized liners form the foundation of their ultra-reliable Compression Lock® mechanisms, while fully configurable four-position pocket clips provide a choice of left or right-side, tip-up or tip-down carry. Generously sized lanyard holes complete the package, allowing the easy attachment of fobs and safety lanyards.
For tactical environments where light discipline is required, the all-black Military 2 Salt cloaks its blade in a stealthy Diamond-Like Carbon (DLC) coating. Its scales are both peel-ply-textured and machined with Spyderco’s signature Caribbean Bi-Directional Texture™ pattern for an ultra-secure grip. Like its DLC-coated blade, this knife’s liners, pocket clip, and all other hardware are also made from ultra-corrosion-resistant materials and have non-reflective black coatings.
The Military 2 Salt is also available with a satin-finished blade and two-toned G-10 scales. The meticulously machined Caribbean Bi-Directional Texture pattern not only ensures a secure, non-slip grip, but also reveals the scales’ alternating black and yellow layers to enhance the knife’s visibility in and around the water.
Technical specifications
Lock
Compression
Blade Length:
4in 102mm
Overall length:
9.51in 242mm
Closed length:
5.51in 140mm
Edge Length:
3.65in 93mm
CPM® MagnaCut®
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
G-10
Knife weight:
4.2oz 119g
Grind:
Frequently bought together
Reviews
