At a glance
3.46" (85mm)
CPM® S110V®
Taiwan
About
This model is no longer in production.
Spyderco’s Mule Team™ Series is an ongoing project that enables steel-obsessed knife enthusiasts to test different blade materials using the same exact fixed-blade design platform. Sold without handles or sheaths, Mule Team blades are also ideal for aspiring knifemakers and hobbyists.
This expression of the Mule Team concept features CPM S110V. CPM S110V blade steel is produced using a CPM - Crucible Particle Metallurgy process developed by Crucible Industries of Solvay, New York, U.S.A.
What differentiates CPM S110V from other blade steels is its volume of vanadium-rich (9.0%) and niobium-rich (3.0%) alloys, which classify it as a martensitic stainless tool steel. Crucible’s powdered metal process creates uniform carbide distribution of the steel’s components throughout the blade for superior wear resistance, toughness, and corrosion protection. These are positive performance characteristics highly desired in state-of-the-art exotic blade steels.
All Mule Team blades are sold consumer-direct and available only at the Spyderco Factory Outlet or through Spyderco.com.
Released: February 2014
Technical specifications
Lock
Blade Length:
3.46" (85mm)
Overall length:
7.63" (194mm)
Closed length:
Edge Length:
3.35" (85mm)
CPM® S110V®
Blade thickness:
0.118" (3mm)
Tip carry position:
Clip position:
Sheath:
Handle material:
Knife weight:
2.7oz (77g)
Grind:
