Skip to product information
SKU:MT01
Mule Team™ 52100 MT01
SKU:MT01
Mule Team™ 52100
$79.95
At a glance
3.5in 89mm
United States
About
This model is no longer in production.
Spyderco’s Mule Team™ Series is an ongoing project that enables steel-obsessed knife enthusiasts to test different blade materials using the same exact fixed-blade design platform. Sold without handles or sheaths, Mule Team blades are also ideal for aspiring knifemakers and hobbyists.
This expression of the Mule Team concept features 52100, a high-carbon steel used primarily for ball bearings. It has a good amount of carbon (0.98 - 1.10) and very few other alloys. Ball bearing steels usually have to withstand a great deal of force in a very small area. Traditionally, ball-bearing steels make good edge steels because an edge also has to withstand extreme force in a small area. 52100 serves that function well.
A very fine molecular structure permits very sharp edges, even at thin angles. Toughness is good, corrosion resistance isn't. It is not a stainless steel and will have to be cared for.
All Mule Team blades are sold consumer-direct and available only at the Spyderco Factory Outlet or through Spyderco.com.
Released: January 2008
Technical specifications
Lock
Blade Length:
3.5in 89mm
Overall length:
7.63in 194mm
Closed length:
Edge Length:
3.4in 86mm
Blade thickness:
.118in 3mm
Tip carry position:
Clip position:
Sheath:
Handle material:
Knife weight:
2.7oz 77g
Grind:
Frequently bought together
Reviews
