Native Chief™ Lightweight Black Blade PlainEdge™ C244PBBK_Both
PlainEdge / DLC
$235.00
Skip to product information
SKU:C244PBBK
SKU:C244PBBK
$235.00
Edge Type
Blade Coating
At a glance
4.02in 102mm
CTS® BD1N
United States
Back Lock
About
An "extended" version of the timeless Spyderco Native®, the Native Chief® stretches the overall length of the original design by about one-third while maintaining its slim, pocket-friendly profile. The Native Chief Lightweight continues that evolution, replacing the G-10 scales with a lightweight, fiberglass-reinforced-nylon (FRN) handle. The injection-molded handle includes a high-traction Bi-Directional Texture™ pattern and its linerless construction trims the knife's weight by 21 percent compared to its G-10 counterpart. It retains the same precision-machined back lock mechanism and includes threaded inserts to allow mounting of the knife's four-position pocket clip to support left or right-side, tip-up or tip-down carry. The blade of the Native Chief Lightweight is full-flat-ground from CTS® BD1N stainless steel and features a fully accessible Trademark Round Hole™ to complement the knife's symmetrical, completely ambidextrous design. This ultra-lightweight cutting tool is available with a tumbled blade finish and brightly finished hardware or in an all-black configuration featuring a Diamond-Like Carbon (DLC) blade coating and matching black-coated lock bar, clip, and hardware. Both finish options also offer a choice of either a PlainEdge™, CombinationEdge™, or fully serrated SpyderEdge™ blade.
Technical specifications
Lock
Back Lock
Blade Length:
4.02in 102mm
Overall length:
9.05in 230mm
Closed length:
5.08in 129mm
Edge Length:
3.52in 89mm
CTS® BD1N
Blade thickness:
.13in 3.2mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
FRN
Knife weight:
3.1oz 88g
Grind:
Frequently bought together
Reviews
