Pacific Salt® 2 H2 PlainEdge TiCN Black C91PBBK2_Both
Pacific Salt® 2 H2
PlainEdge / TiCN / Black
$189.00
Skip to product information
SKU:C91PBBK2
SKU:C91PBBK2
Pacific Salt® 2 H2
$189.00
Edge Type
Blade Coating
Color
At a glance
3.78in 96mm
H-2
Japan
Back Lock
About
The Pacific Salt® 2 proudly offers all the key features of the iconic Endura® 4 Lightweight in an ultra-corrosion-resistant format. These include refined ergonomics, a high-traction Bi-Directional Texture™ pattern on the handle, a high-strength back lock mechanism, and a black-coated titanium pocket clip that supports left or right-side, tip-up or tip-down carry. Unlike the Endura 4, which uses stainless steel liners in the handle, the Pacific Salt 2’s incredibly lightweight linerless handle is molded from two pieces of fiberglass-reinforced nylon (FRN) and fitted with four sets of threaded stainless steel inserts to mount its four-position clip. All other metal hardware on the Pacific Salt 2 is also machined from special marine-grade alloys and black coated for extreme corrosion resistance.
The heart of this version of the Pacific Salt 2 is its hollow-ground blade, which is crafted from H-2—Spyderco’s most corrosion-resistant alloy. Available in both PlainEdge™ and fully serrated SpyderEdge™ configurations, the blade features a fully accessible Trademark Round Hole™ for swift, ambidextrous, one-handed opening.
The H-2-bladed Pacific Salt 2 is available in three versions: a satin-finished blade with a black handle, a satin-finished blade with a high-visibility yellow handle, and an all-black version with a non-reflective titanium carbonitride (TiCN) blade coating and a matching black-coated lock bar and handle hardware. All offer a choice of edge configurations.
Technical specifications
Lock
Back Lock
Blade Length:
3.78in 96mm
Overall length:
8.72in 221mm
Closed length:
4.98in 126mm
Edge Length:
3.39in 86mm
H-2
Blade thickness:
.114in 2.9mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
FRN
Knife weight:
2.9oz 82g
Grind:
Hollow
Frequently bought together
Reviews
