At a glance
2.93in 74mm
CPM® 15V®
United States
Compression
About
This elite Sprint Run® expression of the Para® 3 proudly showcases a blade crafted from CPM® 15V®, an extraordinary material that offers the highest wear resistance of any cold-work tool steel available today. Containing almost 15 percent vanadium, its unique alloy composition creates an exceptionally high volume of vanadium carbides in its microstructure. In knife blades, this translates to breathtaking cutting performance and edge retention. Spyderco’s limited-edition family of CPM 15V knives are further enhanced by a specialized heat-treating protocol developed by acclaimed custom knifemaker Shawn Houston. This Sprint Run expression of the Para 3 faithfully includes all the proven elements of this design, including a high-strength Compression Lock® mechanism and a four-position pocket clip. To clearly distinguish it as a member of our CPM 15V family, it also features brown peel-ply-textured G-10 handle scales and Shawn Houston’s “Triple B” logo laser engraved on the reverse side of the full-flat-ground blade.
Technical specifications
Lock
Compression
CPM® 15V®
Overall length:
7.2in 183mm
Closed length:
4.29in 109mm
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Handle material:
G-10
Knife weight:
3.4oz 96g
Grind:
Clip position:
Ambi
