Para Military® 2 Lightweight Salt® CPM® MagnaCut® PlainEdge C81PYL2_Both
PlainEdge
$253.00
Skip to product information
SKU:C81PYL2
SKU:C81PYL2
$253.00
Edge Type
At a glance
3.47in 88mm
CPM® MagnaCut®
United States
Compression
About
The Para Military 2 Lightweight revolutionized the original version of this iconic design by expressing it in a highly refined lightweight format. More than 25 percent lighter than its G-10-handled counterpart, its injection-molded fiberglass-reinforced-nylon (FRN) handle also offers the enhanced grip security of Spyderco’s proven Bi-Directional Texture™ pattern. However, the streamlined engineering of this remarkable design does more than just trim its weight; it also reduces its number of metal components, making it an ideal candidate for Spyderco’s ultra-corrosion-resistant Salt® Series.
The Para Military 2 Lightweight Salt proudly showcases a full-flat-ground blade crafted from CPM MagnaCut—a revolutionary blade steel that challenges conventional metallurgy to deliver an exceptional balance of edge retention, toughness, and extreme corrosion resistance. Available in both PlainEdge™ and fully serrated SpyderEdge™ formats, the satin-finished blade is paired with a bright yellow FRN handle that enhances the knife’s visibility in and around the water. The handle is also home to the knife’s streamlined Compression Lock® mechanism, a generously sized lanyard hole, and a reversible deep-pocket wire clip that offers a choice of left- or right-side tip-up carry. Like all Salt Series folders, the handle components and hardware of the Para Military 2 Lightweight Salt are also crafted from premium, corrosion-resistant, marine-grade materials.
Lock
Compression
CPM® MagnaCut®
Overall length:
8.29in 211mm
Closed length:
4.82in 122mm
Blade thickness:
.145in 3.7mm
Tip carry position:
Tip-Up
Handle material:
FRN
Knife weight:
2.8oz 78g
Grind:
Clip position:
Ambi
Frequently bought together
Reviews
