Para Military® 2 Lightweight PlainEdge None C81PBK2Both
PlainEdge / None
$202.00
Skip to product information
SKU:C81PBK2
SKU:C81PBK2
$202.00
Edge Type
Blade Coating
At a glance
3.47in 88mm
CTS® BD1N
United States
Compression
About
The Para Military 2 is one of the most popular, recognizable, and carried knives in the world. Now this iconic design is available in a lightweight format that trims the knife’s overall weight by more than 25 percent and adds enhanced grip security. The secrets to its remarkable design start with injection-molded fiberglass-reinforced-nylon (FRN) handle scales. Lighter than G-10, they feature our signature Bi-Directional Texture™ pattern for a high-traction, non-slip grip. They also house a streamlined Compression Lock® mechanism that further reduces the knife’s weight while locking the blade securely open during use.
The business end of the knife showcases a full-flat-ground blade crafted from Carpenter® Technology’s CTS® BD1N, a nitrogen-enriched stainless steel that offers an excellent balance of edge retention, toughness, corrosion resistance, and ease of sharpening. The blade also includes a fully accessible Trademark Round Hole™ for quick, ambidextrous one-handed opening and a textured index-finger choil (finger groove) and thumb ramp for precise control during precise cutting chores.
The standard version of the Para Military 2 Lightweight features a tumble-finished blade and brightly finished handle hardware and is available in both PlainEdge™ and fully serrated SpyderEdge™ formats. For tactical environments where light discipline is a concern—and for those who simply prefer the aesthetics of an all-black knife—it is also available with a Diamond-Like Carbon (DLC) blade coating and matching black-coated handle hardware. All versions of this remarkable knife include a deep-pocket wire clip that is reversible for low-profile left- or right-side tip-up carry and a generously sized lanyard hole for the easy attachment of fobs, lanyards, and safety lines.
Technical specifications
Lock
Compression
Blade Length:
3.47in 88mm
Overall length:
8.29in 211mm
Closed length:
4.82in 122mm
Edge Length:
3.08in 78mm
CTS® BD1N
Blade thickness:
.15in 3.7mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
FRN
Knife weight:
2.8oz 78g
Grind:
Frequently bought together
Reviews
