RockJumper™ SpyderEdge™
At a glance
3.08in 78mm
VG-10
Japan
Back Lock
About
Designed to fit the needs of outdoor enthusiasts and climbers, the RockJumper™ is a lightweight, mid-sized, folding knife that’s born to perform. Its broad VG-10 stainless steel blade has a full-flat grind for optimal edge geometry and a full-length, perfectly straight cutting edge.
Designed for unfailing reliability under pressure, its Wharncliffe profile offers everything from extreme cutting power to scalpel-like precision. The knife’s hand-filling handle is constructed with skeletonized stainless steel liners, fiberglass-reinforced-nylon (FRN) scales, and a stout back lock mechanism with a strong self-close function.
Its Bi-Directional Texture™ pattern ensures a secure, non-slip grip, while a four-position hourglass clip and oversized lanyard hole offer a full range of carry positions. Together with the knife’s other symmetrical features, they make every aspect of the RockJumper’s carry and operation completely ambidextrous.
Technical specifications
Lock
Back Lock
VG-10
Overall length:
7.49in 190mm
Closed length:
4.43in 113mm
Blade thickness:
.118in 3mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
3oz 85g
Grind:
Clip position:
Ambi
