RockJumper™ SpyderEdge™
At a glance
3.08in 78mm
VG-10
Japan
Back Lock
About
Designed to fit the needs of outdoor enthusiasts and climbers, the RockJumper™ is a lightweight, mid-sized, folding knife that’s born to perform. Its broad VG-10 stainless steel blade has a full-flat grind for optimal edge geometry and a full-length, perfectly straight cutting edge.
Designed for unfailing reliability under pressure, its Wharncliffe profile offers everything from extreme cutting power to scalpel-like precision. The knife’s hand-filling handle is constructed with skeletonized stainless steel liners, fiberglass-reinforced-nylon (FRN) scales, and a stout back lock mechanism with a strong self-close function.
Its Bi-Directional Texture™ pattern ensures a secure, non-slip grip, while a four-position hourglass clip and oversized lanyard hole offer a full range of carry positions. Together with the knife’s other symmetrical features, they make every aspect of the RockJumper’s carry and operation completely ambidextrous.
Technical specifications
Lock
Back Lock
Blade Length:
3.08in 78mm
Overall length:
7.49in 190mm
Closed length:
4.43in 113mm
Edge Length:
2.85in 72mm
VG-10
Blade thickness:
.118in 3mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
FRN
Knife weight:
3oz 85g
Grind:
