At a glance
in mm
Japan
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
The iconic Native® has been a mainstay of Spyderco’s American-made product line for decades. The Lil’ Native® distills all the highly evolved performance features of this time-tested design into a compact gentleman’s folder with a legally friendly 2.5-inch blade. Its full-flat-ground CPM® S30V® stainless steel blade includes a prominent index-finger choil that flows seamlessly into the contours of the peel-ply-textured G-10 handle scales. This creates a compact, ergonomic package that still offers a full, four-fingered grip and excellent control. This version of the Lil’ Native goes a step further by adding nested stainless steel liners, our high-strength Compression Lock® mechanism, and a handsome all-black theme. Its fully serrated SpyderEdge™ blade is also cloaked in a non-reflective Diamond-Like Carbon (DLC) coating and complemented by the handle’s black-coated liners, clip, and hardware. To balance low-profile carry and immediate access, this compact cutting tool includes a deep-pocket wire clip that is configurable for left- or right-side tip-up carry.
Technical specifications
Blade Length:
in mm
Overall length:
in mm
Closed length:
in mm
Edge Length:
in mm
Blade thickness:
in mm
Knife weight:
oz g
