At a glance
in mm
United States
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Spyderco’s original Lil’ Native® was created to provide the same proven functionality and reliability as our iconic Native® model in an ultra-compact package with a legally friendly 2.42-inch blade. The Lil’ Native Lightweight proudly continues that evolution with an even leaner, more affordable format. This remarkable folding knife takes the Lil’ Native Back Lock platform and lightens it by 40 percent with fiberglass-reinforced-nylon (FRN) handle scales. The injection-molded scales add the enhanced grip security of a Bi-Directional Texture™ pattern and are home to a reversible deep-pocket wire clip that provides discreet left or right-side tip-up carry. The business end of the knife is a full-flat-ground CTS® BD1N stainless steel blade with a fully accessible Trademark Round Hole™ for easy one-handed opening with either hand. This ultra-lightweight cutting tool is available with a choice of edge styles and blade finishes. This all-black version features a PlainEdge™ blade with a non-reflective Diamond-Like Carbon (DLC) coating and a matching black-coated lock bar, clip, and handle hardware.
Technical specifications
Blade Length:
in mm
Overall length:
9.52in 242mm
Closed length:
in mm
Edge Length:
3.65in mm
Blade thickness:
.15in 3.7mm
Tip carry position:
Tip-Down
Clip position:
Right
Knife weight:
oz g
Grind:
