At a glance
in mm
United States
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Combining the traditional look of brown canvas Micarta® scales with a CPM® CRU-WEAR® tool steel blade, Spyderco’s “CruCarta” theme has become an instant classic. This stunning expression of the Manix® 2 showcases that distinctive old-school combination with impressive style. Its full-flat-ground, satin-finished blade capitalizes on CPM CRU-WEAR’s advanced alloy composition to deliver exceptional edge retention and toughness. A high-strength Ball Bearing Lock™ mechanism links the blade to a handle constructed with full stainless steel liners and a stainless steel backspacer. The liners are capped with smooth, unpolished Micarta scales that will naturally patina with age and handling to develop their own unique character. To ensure convenient carry and instant access, the handle also features a generously sized lanyard hole and a polished hourglass clip that is reversible for left or right-side tip-up carry.
Technical specifications
Blade Length:
in mm
Overall length:
in mm
Closed length:
in mm
Edge Length:
in mm
Blade thickness:
in mm
Knife weight:
oz g
