At a glance
in mm
CPM® S30V®
United States
LinerLock
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
The long-awaited Military 2 enhanced the design of the time-tested Military Model with several significant design improvements, including Spyderco’s signature Compression Lock® mechanism, larger stainless steel liners, and a fully configurable four-position pocket clip. This elite expression of the design takes it to the next level with a blade crafted from CPM S110V—a state-of-the-art particle metallurgy steel enriched with high volumes of vanadium and niobium for exceptional wear resistance, edge retention, and corrosion resistance. Like all members of our CPM S110V family, its peel-ply-textured G-10 handle scales sport a distinctive dark blue color.
Technical specifications
Lock
LinerLock
Blade Length:
in mm
Overall length:
9.52in 242mm
Closed length:
in mm
Edge Length:
3.65in mm
CPM® S30V®
Blade thickness:
.15in 3.7mm
Tip carry position:
Tip-Up/Tip-Down
Clip position:
Ambi
Handle material:
G-10
Knife weight:
oz g
Grind:
