(Seconds) Native Chief® Brown Canvas Micarta® CPM® Cru-Wear®
At a glance
in mm
United States
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
More of a good thing is always better, especially when it comes to Spyderco’s incredibly popular “CruCarta” themed knives. In this case, “more” takes the form of the Native Chief®—an extended version of the popular Native® 5. Faithfully offering all the same qualities as its progenitor, but in a longer, even more capable format, this expression of the Native Chief showcases a full-flat-ground, satin-finished blade precision machined from CPM® CRU-WEAR® tool steel. The blade is housed in a handle constructed with smooth brown canvas Micarta® scales, a high-strength back lock mechanism, a stainless steel backspacer, and a fully configurable four-position pocket clip. A truly impressive example of this “old-school” pairing of materials, this Native Chief commands attention.
Technical specifications
Blade Length:
in mm
Overall length:
in mm
Closed length:
in mm
Edge Length:
in mm
Blade thickness:
in mm
Knife weight:
oz g
