(Seconds) Native Chief™ Lightweight Salt® LC200N PlainEdge™ C244PGR_Both_50b26eb9-0b6c-4b37-82f6-381ac588bdb9
$88.00
Skip to product information
SKU:XXC244PGR
SKU:XXC244PGR
$88.00
At a glance
in mm
United States
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Twenty-one percent lighter than its G-10- handled counterpart, the Native Chief® Lightweight features a linerless fiberglass-reinforced-nylon (FRN) handle and a high-traction Bi-Directional Texture™ pattern for a positive, non-slip grip. Those qualities made it an ideal candidate for inclusion in Spyderco’s remarkable Salt® Series of knives specifically designed for use in and around the water. This Native Chief Lightweight Salt® showcases a full-flat-ground blade precision machined from ultra-corrosion-resistant LC200N steel, best known as NASA’s material of choice for ball bearings used in spacecraft. Available in a choice of edge configurations, the blade is paired with a linerless FRN handle injection molded in the signature high-visibility green color of our LC200N lightweight Salt family. The vibrant handle also houses the knife’s sturdy back lock mechanism and includes four sets of threaded inserts to allow fully configurable mounting of a four-position pocket clip. Like all our Salt Series folders, the clip and hardware of this PlainEdge™ version of the knife are also crafted from ultra-corrosion-resistant, marine-grade materials and select parts are further enhanced with proprietary black coatings.
Technical specifications
Blade Length:
in mm
Overall length:
9.52in 242mm
Closed length:
in mm
Edge Length:
3.65in mm
Blade thickness:
.15in 3.2mm
Tip carry position:
Tip-Down
Clip position:
Right
Knife weight:
oz g
Grind:
Frequently bought together
Reviews
