At a glance
in mm
CTS® BD1N
United States
Compression
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Spyderco’s best-selling Para® 3 distills all the key qualities of the time-tested Para Military® 2 model into an ultra-compact, carry-friendly format. The Para 3 Lightweight raises that bar even higher by incorporating injection-molded fiberglass-reinforced-nylon (FRN) scales and a streamlined version of our Compression Lock® mechanism to create a knife that is almost 30 percent lighter than its G-10-handled counterparts. The Para 3 Lightweight boasts a linerless, open-backed construction and a high-traction Bi-Directional Texture™ pattern for a secure grip. A stainless steel lock bar inset into the handle’s interior forms the foundation of its sturdy lock mechanism, while keeping the overall weight to an absolute minimum. Available with a choice of two edge formats, the knife’s full-flat-ground blade is crafted from CTS® BD1N, a nitrogen-enriched high-carbon chromium steel that offers a superior balance of hardness, edge retention, and corrosion resistance. The PlainEdge™ blade of this version features a fully accessible Trademark Round Hole™ for swift, positive, one-handed opening with either hand. To balance convenient carry and immediate access, the Para 3 Lightweight also includes a generously sized lanyard hole and a reversible deep-pocket wire clip. Together, they provide discreet left- or right-side tip-up carry and allow the easy attachment of fobs or lanyards.
Technical specifications
Lock
Compression
Blade Length:
in mm
Overall length:
7.21in 183mm
Closed length:
in mm
Edge Length:
2.58in mm
CTS® BD1N
Blade thickness:
.15in 3.7mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
FRN
Knife weight:
oz g
Grind:
