At a glance
in mm
CPM® SPY27®
United States
Compression
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Spyderco has long been an industry leader in the use of exotic, high-performance blade steels. After years of using the best materials the world’s leading steel manufacturers could provide, we decided it was time to create our own. In close cooperation with Crucible® Industries, we developed CPM® SPY27®, a particle metallurgy stainless steel containing a proprietary mix of alloys, including vanadium, molybdenum, niobium, nitrogen, and cobalt. Produced exclusively for Spyderco, it forms the heart of this elite expression of the Para® 3 Lightweight. The full-flat-ground blade of this knife capitalizes on SPY27’s unique properties to deliver an exceptional balance of edge retention, toughness, and corrosion resistance. It is paired with an ultra-lightweight handle made from fiberglass-reinforced nylon (FRN). Injection molded in a distinctive blue—one of the signature colors of our CPM SPY27 family—the handle contains the knife’s streamlined Compression Lock® mechanism to lock the blade securely open during use. It also features a non-slip Bi-Directional Texture™ pattern and a reversible deep-pocket wire clip that provides discreet tip-up carry on either side of the body.
Technical specifications
Lock
Compression
Blade Length:
in mm
Overall length:
7.21in 183mm
Closed length:
in mm
Edge Length:
2.58in mm
CPM® SPY27®
Blade thickness:
.15in 3.7mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
FRN
Knife weight:
oz g
Grind:
