At a glance
in mm
VG-10
United States
Back Lock
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
The Para® 3 takes all the proven features and benefits of Spyderco’s best-selling Para Military® 2 and distills them into an even more compact all-purpose cutting tool. Its three-inch blade is precision machined from premium CPM® S45VN™ stainless steel and features a full-flat grind for a superior balance of strength, point utility, and low-friction cutting performance. It includes a textured index-finger choil and thumb ramp that provide a solid purchase for a forward-positioned grip, offering enhanced control during precise cutting tasks. The blade’s signature Trademark Round Hole™ proudly brands it as a member of the Spyderco family and is fully accessible to allow quick, positive, one-handed opening with either hand. To keep the Para 3 slim and pocket friendly, it features a lightweight, open-backed construction style and its stainless steel liners are nested into machined recesses in the peel-ply-textured G-10 scales. This provides excellent structural support for the knife’s Compression Lock® mechanism, which locks the blade securely open during use while allowing it to be closed easily and safely with only one hand. A four-position hourglass clip and an oversized lined lanyard hole complete the design, offering ambidextrous tip-up or tip-down carry and allowing the easy attachment of fobs and lanyards.
The Para 3 with CPM S45VN blade steel is available in several different variations. This version cloaks its PlainEdge™ blade in a non-reflective Diamond-Like Carbon (DLC) coating and pairs it with a handle featuring digital camouflage G-10 scales and black-coated liners and handle hardware.
Technical specifications
Lock
Back Lock
Blade Length:
in mm
Overall length:
9.47in 241mm
Closed length:
in mm
Edge Length:
3.76in mm
VG-10
Blade thickness:
.12in 3mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
Stainless Steel
Knife weight:
oz g
Grind:
Hollow
