(Seconds) Para® 3 Salt® Yellow/Black G-10 CPM® MagnaCut® C223GBKYLMCP_Both_35e6b675-c924-41ae-92e3-7981f436805f
$110.00
Skip to product information
SKU:XXC223GBKYLMCP
SKU:XXC223GBKYLMCP
$110.00
At a glance
in mm
CPM® S30V®
United States
Compression
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
This remarkable expression of the Para® 3 ushers this practical, pocket-friendly design into Spyderco’s Salt® Series—knives specifically designed for use in and around the water. The satin-finished, full-flat-ground blade of this Para 3 Salt is crafted from CPM® MagnaCut®—a state-of-the-art particle metallurgy steel that offers an exceptional balance of edge retention, toughness, and superior corrosion resistance. Designed for high visibility in aquatic environments, the knife’s handle features layered, two-toned G-10 scales with a Caribbean Bi-Directional Texture™ pattern. This precision-machined pattern reveals the contrasting colors of the black-and-yellow G-10 and ensures a secure, non-slip grip. The scales are supported by nested, skeletonized stainless steel liners that form the foundation of an ultra-reliable Compression Lock® mechanism. They also anchor a fully configurable four-position pocket clip that provides a choice of left- or right-side, tip-up or tip-down carry. To complete the package, the handle hardware of this Para 3 Salt is also crafted from ultra-corrosion-resistant, marine-grade materials enhanced by durable black coatings.
Technical specifications
Lock
Compression
Blade Length:
in mm
Overall length:
7.24in 184mm
Closed length:
in mm
Edge Length:
2.62in mm
CPM® S30V®
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
G-10
Knife weight:
oz g
Grind:
Frequently bought together
Reviews
