(Seconds) Para Military® 2 Brown Canvas Micarta® CPM® Cru-Wear®
At a glance
in mm
CPM® Cru-Wear®
United States
Compression
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
This stunning expression of the iconic Para Military® 2 pairs a CPM® CRU-WEAR® blade with classic brown canvas Micarta® handle scales; Spyderco's “CruCarta” theme has become a popular classic. Its full-flat-ground PlainEdge™ blade capitalizes on CRU-WEAR’s hard-earned reputation for taking and holding a superior edge while remaining tough and resilient.
The precision-machined scales are supported by full skeletonized stainless steel liners that also form the backbone of the knife’s Compression Lock® mechanism. They reveal the Micarta’s handsome layered construction and provide a platform for a four-position pocket clip and lined lanyard hole that support all possible carry positions and preferences.
Technical specifications
Lock
Compression
Blade Length:
in mm
Overall length:
8.29in 211mm
Closed length:
in mm
Edge Length:
3.1in mm
CPM® Cru-Wear®
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
Micarta
Knife weight:
oz g
Grind:
