At a glance
in mm
CPM® S45VN®
United States
Compression
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Undeniably one of Spyderco’s most popular and in-demand designs, the Para Military® 2 distills the world-class performance of our legendary Military™ Model into a more compact, pocket-friendly package. Not content with that feat, it then added the extreme strength, reliability, and ease of use of our Compression Lock® mechanism and the versatility of a four-position pocket clip. The Para Military 2 is available with a choice of several different blade steels, finishes, edge configurations, and handle colors. This version of the design features a full-flat-ground PlainEdge™ blade crafted from CPM® S45VN® particle metallurgy stainless steel and digital camouflage G-10 handle scales. The satin-finished blade includes a textured index-finger choil and thumb ramp that provide a solid purchase for a forward-positioned grip, offering enhanced control during precise cutting tasks. Its signature Trademark Round Hole™ proudly brands it as a member of the Spyderco family and is fully accessible to allow quick, positive, one-handed opening with either hand. To keep the knife slim and pocket friendly, it features a lightweight, open-backed construction style and its skeletonized stainless steel liners are nested into machined recesses in the peel-ply-textured G-10 scales. This provides excellent structural support for the knife’s Compression Lock® mechanism, which locks the blade securely open during use while allowing it to be closed easily and safely with only one hand. A four-position hourglass clip and an oversized lined lanyard hole complete the design, offering ambidextrous tip-up or tip-down carry and allowing the easy attachment of fobs and lanyards
Technical specifications
Lock
Compression
Blade Length:
in mm
Overall length:
8.26in 210mm
Closed length:
in mm
Edge Length:
3.05in mm
CPM® S45VN®
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
G-10
Knife weight:
oz g
Grind:
