At a glance
in mm
CPM® S100V
United States
Compression
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
One of the most popular and in-demand folding knives ever created, the Para Military® 2 distills the performance and reliability of the Military™ Model into a more compact, pocket-friendly format. It also adds the advantage of Spyderco’s Compression Lock® mechanism—a high-strength lock that allows the knife to be closed one handed without placing your fingers in the path of the edge.
This elite version of the Para Military 2 supercharges its advanced design with a full-flat-ground blade crafted from Crucible’s CPM® S110V®—a state-of-the-art stainless tool steel produced by the Crucible® Particle Metallurgy (CPM) process. CPM S110V’s high volume of vanadium and niobium alloys give it exceptional wear resistance, while its enhanced chromium content makes it extremely corrosion resistant.
Like all our knives with CPM S110V blades, the textured G-10 handle scales of this version of the Para Military 2 sport a distinctive dark blue color. They are also home to a four-position hourglass clip that supports left and right-side, tip-up or tip-down carry.
Technical specifications
Lock
Compression
Blade Length:
in mm
Overall length:
8.24in 209mm
Closed length:
in mm
Edge Length:
3.04in mm
CPM® S100V
Blade thickness:
.15in 3.7mm
Tip carry position:
4-Position
Clip position:
Ambi
Handle material:
G-10
Knife weight:
oz g
Grind:
