At a glance
in mm
CPM® S30V®
United States
Ball Bearing
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
The Para Military 2 is one of the most popular, recognizable, and carried knives in the world. Now this iconic design is available in a lightweight format that trims the knife’s overall weight by more than 25 percent and adds enhanced grip security. The secrets to its remarkable design start with injection-molded fiberglass-reinforced-nylon (FRN) handle scales. Lighter than G-10, they feature our signature Bi-Directional Texture™ pattern for a high-traction, non-slip grip. They also house a streamlined Compression Lock® mechanism that further reduces the knife’s weight while locking the blade securely open during use.
The business end of the knife showcases a full-flat-ground blade crafted from Carpenter® Technology’s CTS® BD1N, a nitrogen-enriched stainless steel that offers an excellent balance of edge retention, toughness, corrosion resistance, and ease of sharpening. The blade also includes a fully accessible Trademark Round Hole™ for quick, ambidextrous one-handed opening and a textured index-finger choil (finger groove) and thumb ramp for precise control during precise cutting chores. This PlainEdge™ version of the Para Military 2 Lightweight features a satin-finished blade and brightly finished handle hardware. To balance convenient carry and immediate access, it includes a deep-pocket wire clip that is reversible for low-profile left- or right-side tip-up carry and a generously sized lanyard hole for the easy attachment of fobs, lanyards, and safety lines.
Technical specifications
Lock
Ball Bearing
Blade Length:
in mm
Overall length:
8.03in 204mm
Closed length:
in mm
Edge Length:
2.92in mm
CPM® S30V®
Blade thickness:
.13in 3.7mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
G-10
Knife weight:
oz g
Grind:
