At a glance
in mm
CPM® S30V®
United States
LinerLock
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
The Bodacious™ is a stout, full-service folding knife designed for unfailing reliability. This limited-edition Sprint Run® expression of it supercharges the design with a satin-finished blade crafted from Crucible® CPM® S90V®—a vanadium-enriched powder metallurgy stainless steel that provides an exceptional balance of edge retention and corrosion resistance. The PlainEdge™ blade of this knife is full-flat ground for low-friction edge geometry and features a fully accessible Trademark Round Hole™ for swift, ambidextrous, one-handed opening. Not to be outdone, the handle showcases solid carbon fiber scales with a subtle peel-ply texture. Visually stunning, lightweight, and incredibly strong, the scales are machined to house nested, skeletonized stainless steel liners that form the foundation of the knife’s high-strength Compression Lock® mechanism. A broad-based hourglass pocket clip completes the package, providing a choice of left- or right-side tip-up carry.
Technical specifications
Lock
LinerLock
Blade Length:
in mm
Overall length:
9.52in 242mm
Closed length:
in mm
Edge Length:
3.65in mm
CPM® S30V®
Blade thickness:
.15in 3.2mm
Tip carry position:
Tip-Down
Clip position:
Right
Handle material:
G-10
Knife weight:
oz g
Grind:
