(Seconds) Lil' Native® Mid Back Lock Brown G-10 CPM® 15V® Sprint Run® C230MBGPBN15VBoth_4e90a74f-0836-43a6-b025-199f115ef321
$97.00
Skip to product information
SKU:XXC230MBGPBN15V
SKU:XXC230MBGPBN15V
$97.00
At a glance
in mm
United States
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
A scaled-down expression of our revered Native® model, the Lil’ Native Mid Back Lock proudly delivers all the same features and benefits in a gentleman’s folder format. This elite Sprint Run edition elevates the design even further with a full-flat-ground blade made from CPM 15V. Containing almost 15 percent vanadium, its remarkable alloy composition produces an exceptionally high volume of ultra-hard vanadium carbides and gives it the highest wear resistance of any cold-work tool steel available today. To successfully translate these properties to knife blades, Spyderco’s CPM 15V knives are also hardened and tempered using a specialized protocol developed by custom knifemaker Shawn Houston. This limited-edition expression of the Lil’ Native faithfully includes the stout back lock and broad-based four-position pocket clip of the standard model. It also features brown peel-ply-textured G-10 handle scales and Shawn Houston’s “Triple B” logo laser engraved on the reverse side of the blade.
Technical specifications
Blade Length:
in mm
Overall length:
in mm
Closed length:
in mm
Edge Length:
in mm
Blade thickness:
in mm
Knife weight:
oz g
Frequently bought together
Reviews
