(Seconds) Massad Ayoob Sprint Run™ C60Massad_951635ae-063f-42b9-a8a2-c77936889069
$134.00
Skip to product information
SKU:XXC60GSGY
SKU:XXC60GSGY
$134.00
At a glance
in mm
VG-10
Japan
Back Lock
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Designed by world-renowned firearms expert Massad Ayoob and originally introduced in 2001, the Massad Ayoob folding knife featured a distinctive negative angle between its blade and handle. This aligns the blade with the bones in the forearm to ensure a more direct transfer of force during thrusting and cutting motions and shortens the blade’s opening arc. This long-awaited Sprint Run expression of Ayoob’s design features a blade crafted from CPM CRU-WEAR® — a specially formulated air-hardening tool steel renowned for its edge holding and toughness. Its handle features full, skeletonized stainless steel liners, a sturdy back lock mechanism, distinctive gray peel-ply-textured G-10 scales, and a black-coated four-position pocket clip that provides a choice of left or right-side tip-up or tip-down carry.
Technical specifications
Lock
Back Lock
Blade Length:
in mm
Overall length:
in mm
Closed length:
in mm
Edge Length:
in mm
VG-10
Blade thickness:
in mm
Tip carry position:
4-Position
Handle material:
FRN
Knife weight:
oz g
Grind:
Frequently bought together
Reviews
