At a glance
in mm
CPM® S30V®
United States
LinerLock
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
This elite Sprint Run® expression of the MicroJimbo® proudly showcases a blade crafted from CPM® 15V®, a remarkable material that offers the highest wear resistance of any cold-work tool steel available today. Containing almost 15 percent vanadium, its advanced alloy composition creates an exceptionally high volume of vanadium carbides in its microstructure. In knife blades, this translates to unparalleled cutting performance and edge retention. Spyderco’s limited-edition CPM 15V knives are further enhanced by a specialized heat-treating protocol developed by acclaimed custom knifemaker Shawn Houston. This Sprint Run MicroJimbo faithfully includes all the proven elements of this design, including a high-strength Compression Lock® mechanism and a reversible deep-pocket wire clip. To clearly distinguish it as a member of our CPM 15V family, it also features brown peel-ply-textured G-10 handle scales and Shawn Houston’s “Triple B” logo laser engraved on the reverse side of the full-flat-ground blade.
Technical specifications
Lock
LinerLock
Blade Length:
in mm
Overall length:
9.52in 242mm
Closed length:
in mm
Edge Length:
3.65in mm
CPM® S30V®
Blade thickness:
.15in 3.7mm
Tip carry position:
Tip-Up/Tip-Down
Clip position:
Ambi
Handle material:
G-10
Knife weight:
oz g
Grind:
