At a glance
in mm
LC200N
United States
Back Lock
About
Purchase Limit: 4
This product is being sold as a Factory Second. If a knife or other product doesn’t meet our stringent quality-control standards, it is declared a Factory Second and removed from our first-quality inventory.
Typically, products are declared seconds because they have some kind of minor cosmetic flaw or because they do not satisfy a non-critical quality-control standard. While these flaws may affect the product’s appearance, they do not compromise its proper mechanical operation. Regardless of the specific reason a knife is declared a second, it remains safe for normal use. To clearly differentiate our Factory Seconds from our first-quality products, knives are all marked with a small notch on the spine of the blade near the handle.
Due to the nature of Factory Seconds, we are not able to accommodate special requests. All products are drawn randomly from inventory pre-selected for the sale. No hand-picking will be done.
Although Factory Seconds are fully functional and ideal for utilitarian use, they are not covered under Spyderco’s standard warranty policy and may not be returned to Spyderco for service. They are sold “as is” at substantial discounts, and all sales are final.
Professional kayak fisherman Lance Clinton spends much of his life using knives in and around the water. That hard-earned experience inspired him to design the Siren--a full-service folding knife optimized for the needs of fishermen and watersports enthusiasts.
Its full-flat-ground blade is crafted from ultra-corrosion-resistant LC200N steel and supported by a stout back lock mechanism. To ensure a secure, non-slip grip in wet conditions, the blade is paired with a coarse-textured G-10 handle with a substantial integral guard. Both G-10 scales include a stylish blue accent layer and house a reversible deep-pocket wire clip that balances secure carry with quick access.
Technical specifications
Lock
Back Lock
Blade Length:
in mm
Overall length:
8.73in 222mm
Closed length:
in mm
Edge Length:
3.49in mm
LC200N
Blade thickness:
.13in 3.2mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
G-10
Knife weight:
oz g
Grind:
