At a glance
3.42in 86.868mm
M390
Italy
R.I.L.
About
Produced by lionSTEEL® exclusively for Spyderco, the Slym™ elevates Michele Pensato’s popular Skinny design with the user friendliness of our Trademark Round Hole in the blade. This lean folder features a full-flat-ground, drop-point blade crafted from Böhler-Uddeholm’s M390 particle metallurgy stainless steel. In addition to its fully accessible Round Hole, the stonewash finished blade also includes a removeable flipper tab and rides on ball-bearing washers for an ultra-smooth action. The Slym’s unique handle is precision machined from a single piece of titanium using lionSTEEL’s SOLID® technology. It also boasts a durable gray physical vapor deposition (PVD) coating and a black-and-white Dark Matter Polar Fat Carbon Fiber inlay on the obverse side. The handle’s reverse side is home to a sturdy Reeve Integral Lock™ (R.I.L.) mechanism that includes a long-wearing hardened steel interface. To keep the knife poised for instant access, the handle also features both a generously sized lanyard hole and a butt-mounted, deep-pocket clip that is reversible for left or right-side carry.
Lock
R.I.L.
M390
Technical specifications
Overall length:
7.84in 199.136mm
Closed length:
4.43in 112.522mm
Blade thickness:
.135in 3.4mm
Tip carry position:
Tip-Up
Handle material:
Titanium/Carbon Fiber
Knife weight:
3.4oz 96.39g
Grind:
Clip position:
Ambi
